46-421 question
Read through threads & Chucks advice, & it is GOOD reading
since I'd never run across one of these.
In the threads, Sparky mentions that the old foil caps seldom
go bad. I would have to differ with that--most need replaced.
Bob---did you have to "tune" the coil when you replaced the
cap in yours? Just wondering for future.
This is actually a set for the radio Grandson for a 4-H project,
so all this info is much appreciated. He's already done several
old units already.
Thanks much, guys.
Jim
46-421 question - by brownie45 - 04-01-2015, 08:45 AM
RE: 46-421 question - by klondike98 - 04-01-2015, 09:55 AM
RE: 46-421 question - by brownie45 - 04-01-2015, 10:02 AM
RE: 46-421 question - by Radioroslyn - 04-01-2015, 09:09 PM
RE: 46-421 question - by brownie45 - 04-02-2015, 07:50 AM
RE: 46-421 question - by klondike98 - 04-02-2015, 09:54 AM
RE: 46-421 question - by brownie45 - 04-02-2015, 05:53 PM
RE: 46-421 question - by Radioroslyn - 04-02-2015, 07:24 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
