  • 1 Vote(s) - 1 Average
Model 37-84 Help Needed
Dave
actually Terry asked you to measure from Antenna post to Gnd, and not from pin 2. While it is a useful measurement and might seem the same, it is not.
Now, just to close this step, could you measure from Ant to Gnd
1. with volume fully up
2. with volume fully down.
Model 37-84 Help Needed - by dseverson - 04-01-2015, 02:19 PM
RE: Model 37-84 Help Needed - by morzh - 04-01-2015, 03:08 PM
RE: Model 37-84 Help Needed - by dseverson - 04-01-2015, 05:59 PM
RE: Model 37-84 Help Needed - by morzh - 04-01-2015, 07:22 PM
RE: Model 37-84 Help Needed - by Radioroslyn - 04-01-2015, 08:29 PM
RE: Model 37-84 Help Needed - by dseverson - 04-01-2015, 11:30 PM
RE: Model 37-84 Help Needed - by Radioroslyn - 04-01-2015, 11:50 PM
RE: Model 37-84 Help Needed - by dseverson - 04-02-2015, 01:03 AM
RE: Model 37-84 Help Needed - by Radioroslyn - 04-02-2015, 07:07 AM
RE: Model 37-84 Help Needed - by morzh - 04-02-2015, 09:14 AM
RE: Model 37-84 Help Needed - by dseverson - 04-02-2015, 01:29 PM
RE: Model 37-84 Help Needed - by dseverson - 04-02-2015, 01:30 PM
RE: Model 37-84 Help Needed - by morzh - 04-02-2015, 01:37 PM
RE: Model 37-84 Help Needed - by dseverson - 04-02-2015, 02:55 PM
RE: Model 37-84 Help Needed - by morzh - 04-02-2015, 03:26 PM
RE: Model 37-84 Help Needed - by dseverson - 04-03-2015, 09:47 PM
RE: Model 37-84 Help Needed - by Radioroslyn - 04-03-2015, 10:39 PM
RE: Model 37-84 Help Needed - by dseverson - 04-04-2015, 01:35 AM
RE: Model 37-84 Help Needed - by Radioroslyn - 04-04-2015, 08:14 AM
RE: Model 37-84 Help Needed - by morzh - 04-04-2015, 10:56 AM
RE: Model 37-84 Help Needed - by dseverson - 04-05-2015, 12:49 AM
RE: Model 37-84 Help Needed - by Ron Ramirez - 04-05-2015, 07:15 AM
RE: Model 37-84 Help Needed - by Radioroslyn - 04-05-2015, 03:09 PM
RE: Model 37-84 Help Needed - by morzh - 04-05-2015, 05:26 PM
RE: Model 37-84 Help Needed - by dseverson - 04-06-2015, 12:10 AM
RE: Model 37-84 Help Needed - by Radioroslyn - 04-06-2015, 09:06 AM
RE: Model 37-84 Help Needed - by morzh - 04-06-2015, 09:28 AM
RE: Model 37-84 Help Needed - by dseverson - 04-06-2015, 11:49 AM
RE: Model 37-84 Help Needed - by Radioroslyn - 04-06-2015, 05:27 PM
RE: Model 37-84 Help Needed - by dseverson - 04-06-2015, 10:26 PM
RE: Model 37-84 Help Needed - by Radioroslyn - 04-06-2015, 10:41 PM
RE: Model 37-84 Help Needed - by dseverson - 04-08-2015, 01:00 AM
RE: Model 37-84 Help Needed - by dseverson - 04-17-2015, 01:05 AM
RE: Model 37-84 Help Needed - by Radioroslyn - 04-18-2015, 06:35 PM
RE: Model 37-84 Help Needed - by dseverson - 06-07-2015, 01:54 PM
RE: Model 37-84 Help Needed - by Radioroslyn - 06-07-2015, 03:35 PM
RE: Model 37-84 Help Needed - by dseverson - 06-08-2015, 01:55 PM
RE: Model 37-84 Help Needed - by dseverson - 06-08-2015, 02:31 PM
RE: Model 37-84 Help Needed - by morzh - 06-08-2015, 02:47 PM
RE: Model 37-84 Help Needed - by dseverson - 06-08-2015, 04:01 PM
RE: Model 37-84 Help Needed - by morzh - 06-08-2015, 04:08 PM
RE: Model 37-84 Help Needed - by Radioroslyn - 06-08-2015, 05:05 PM
RE: Model 37-84 Help Needed - by morzh - 06-08-2015, 05:42 PM
RE: Model 37-84 Help Needed - by dseverson - 06-08-2015, 11:06 PM
RE: Model 37-84 Help Needed - by dseverson - 06-10-2015, 02:15 PM
RE: Model 37-84 Help Needed - by Ron Ramirez - 06-10-2015, 03:18 PM
RE: Model 37-84 Help Needed - by dseverson - 06-10-2015, 03:50 PM
RE: Model 37-84 Help Needed - by Ron Ramirez - 06-10-2015, 05:40 PM
RE: Model 37-84 Help Needed - by dseverson - 06-10-2015, 06:19 PM
RE: Model 37-84 Help Needed - by Ron Ramirez - 06-10-2015, 06:28 PM
There are currently 6072 online users. [Complete List]
» 2 Member(s) | 6070 Guest(s)
