46-421 question
Nope, no tuning of the coil required.
46-421 question - by brownie45 - 04-01-2015, 08:45 AM
RE: 46-421 question - by klondike98 - 04-01-2015, 09:55 AM
RE: 46-421 question - by brownie45 - 04-01-2015, 10:02 AM
RE: 46-421 question - by Radioroslyn - 04-01-2015, 09:09 PM
RE: 46-421 question - by brownie45 - 04-02-2015, 07:50 AM
RE: 46-421 question - by klondike98 - 04-02-2015, 09:54 AM
RE: 46-421 question - by brownie45 - 04-02-2015, 05:53 PM
RE: 46-421 question - by Radioroslyn - 04-02-2015, 07:24 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
