  • 1 Vote(s) - 1 Average
Model 37-84 Help Needed
By 0 do you mean...zero? or infinity? (open)
Can't be zero (shorted).
If open, your volume pot is open end to end and this what may be causing your problems.
It should read low ohms (single to maybe 10 or so) when volume is fully UP, and 20Kohm when fully DOWN.
Model 37-84 Help Needed - by dseverson - 04-01-2015, 02:19 PM
RE: Model 37-84 Help Needed - by morzh - 04-01-2015, 03:08 PM
RE: Model 37-84 Help Needed - by dseverson - 04-01-2015, 05:59 PM
RE: Model 37-84 Help Needed - by morzh - 04-01-2015, 07:22 PM
RE: Model 37-84 Help Needed - by Radioroslyn - 04-01-2015, 08:29 PM
RE: Model 37-84 Help Needed - by dseverson - 04-01-2015, 11:30 PM
RE: Model 37-84 Help Needed - by Radioroslyn - 04-01-2015, 11:50 PM
RE: Model 37-84 Help Needed - by dseverson - 04-02-2015, 01:03 AM
RE: Model 37-84 Help Needed - by Radioroslyn - 04-02-2015, 07:07 AM
RE: Model 37-84 Help Needed - by morzh - 04-02-2015, 09:14 AM
RE: Model 37-84 Help Needed - by dseverson - 04-02-2015, 01:29 PM
RE: Model 37-84 Help Needed - by dseverson - 04-02-2015, 01:30 PM
RE: Model 37-84 Help Needed - by morzh - 04-02-2015, 01:37 PM
RE: Model 37-84 Help Needed - by dseverson - 04-02-2015, 02:55 PM
RE: Model 37-84 Help Needed - by morzh - 04-02-2015, 03:26 PM
RE: Model 37-84 Help Needed - by dseverson - 04-03-2015, 09:47 PM
RE: Model 37-84 Help Needed - by Radioroslyn - 04-03-2015, 10:39 PM
RE: Model 37-84 Help Needed - by dseverson - 04-04-2015, 01:35 AM
RE: Model 37-84 Help Needed - by Radioroslyn - 04-04-2015, 08:14 AM
RE: Model 37-84 Help Needed - by morzh - 04-04-2015, 10:56 AM
RE: Model 37-84 Help Needed - by dseverson - 04-05-2015, 12:49 AM
RE: Model 37-84 Help Needed - by Ron Ramirez - 04-05-2015, 07:15 AM
RE: Model 37-84 Help Needed - by Radioroslyn - 04-05-2015, 03:09 PM
RE: Model 37-84 Help Needed - by morzh - 04-05-2015, 05:26 PM
RE: Model 37-84 Help Needed - by dseverson - 04-06-2015, 12:10 AM
RE: Model 37-84 Help Needed - by Radioroslyn - 04-06-2015, 09:06 AM
RE: Model 37-84 Help Needed - by morzh - 04-06-2015, 09:28 AM
RE: Model 37-84 Help Needed - by dseverson - 04-06-2015, 11:49 AM
RE: Model 37-84 Help Needed - by Radioroslyn - 04-06-2015, 05:27 PM
RE: Model 37-84 Help Needed - by dseverson - 04-06-2015, 10:26 PM
RE: Model 37-84 Help Needed - by Radioroslyn - 04-06-2015, 10:41 PM
RE: Model 37-84 Help Needed - by dseverson - 04-08-2015, 01:00 AM
RE: Model 37-84 Help Needed - by dseverson - 04-17-2015, 01:05 AM
RE: Model 37-84 Help Needed - by Radioroslyn - 04-18-2015, 06:35 PM
RE: Model 37-84 Help Needed - by dseverson - 06-07-2015, 01:54 PM
RE: Model 37-84 Help Needed - by Radioroslyn - 06-07-2015, 03:35 PM
RE: Model 37-84 Help Needed - by dseverson - 06-08-2015, 01:55 PM
RE: Model 37-84 Help Needed - by dseverson - 06-08-2015, 02:31 PM
RE: Model 37-84 Help Needed - by morzh - 06-08-2015, 02:47 PM
RE: Model 37-84 Help Needed - by dseverson - 06-08-2015, 04:01 PM
RE: Model 37-84 Help Needed - by morzh - 06-08-2015, 04:08 PM
RE: Model 37-84 Help Needed - by Radioroslyn - 06-08-2015, 05:05 PM
RE: Model 37-84 Help Needed - by morzh - 06-08-2015, 05:42 PM
RE: Model 37-84 Help Needed - by dseverson - 06-08-2015, 11:06 PM
RE: Model 37-84 Help Needed - by dseverson - 06-10-2015, 02:15 PM
RE: Model 37-84 Help Needed - by Ron Ramirez - 06-10-2015, 03:18 PM
RE: Model 37-84 Help Needed - by dseverson - 06-10-2015, 03:50 PM
RE: Model 37-84 Help Needed - by Ron Ramirez - 06-10-2015, 05:40 PM
RE: Model 37-84 Help Needed - by dseverson - 06-10-2015, 06:19 PM
RE: Model 37-84 Help Needed - by Ron Ramirez - 06-10-2015, 06:28 PM
There are currently 3914 online users. [Complete List]
» 1 Member(s) | 3913 Guest(s)
