Threads: 55
City: Lexington, KY
They're not all Ingraham cabinets, and many that are claimed to be really aren't. Ingraham made fancy clocks with cabinets in complex shapes. As radios became smaller they obviously branched into radio cabinets. The most commonly seen are Emerson, but they made some for a few others as well.
RE: Mikes 16B - by Eliot Ness - 04-02-2015, 03:37 PM
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 9123 online users. [Complete List] » 2 Member(s) | 9121 Guest(s)
