Gilfillan 5B8
(04-01-2015, 09:32 PM)Radioroslyn Wrote:  <when you say reflow the solder on the pins of 6Q7, are you talking the actual pins on the tube?
Yep.
Sigal injector should work fine. You may have a little trouble finding those BC xsistor as they are from the UK. They probably crossover to some generic easy to find ones. Not much on three wire fuse technology.
And the chassis pics are where??
OK.  I'll take a shot at reflowing the solder on the pins of 6Q7 and either building that signal injector or seeing if I can find a low price one somewhere.
Still working on the chassis pics.  I have to upload them to my computer and resize them.
Gilfillan 5B8 - by dseverson - 03-26-2015, 02:54 PM
RE: Gilfillan 5B8 - by Radioroslyn - 03-26-2015, 06:21 PM
RE: Gilfillan 5B8 - by dseverson - 03-27-2015, 09:26 PM
RE: Gilfillan 5B8 - by dseverson - 03-27-2015, 09:30 PM
RE: Gilfillan 5B8 - by Radioroslyn - 03-27-2015, 09:48 PM
RE: Gilfillan 5B8 - by dseverson - 03-28-2015, 12:53 AM
RE: Gilfillan 5B8 - by Radioroslyn - 03-28-2015, 07:03 AM
RE: Gilfillan 5B8 - by dseverson - 03-28-2015, 08:49 PM
RE: Gilfillan 5B8 - by Radioroslyn - 03-28-2015, 09:33 PM
RE: Gilfillan 5B8 - by dseverson - 03-30-2015, 12:13 AM
RE: Gilfillan 5B8 - by Radioroslyn - 03-30-2015, 08:39 AM
RE: Gilfillan 5B8 - by dseverson - 03-30-2015, 05:54 PM
RE: Gilfillan 5B8 - by dseverson - 04-01-2015, 02:30 PM
RE: Gilfillan 5B8 - by Radioroslyn - 04-01-2015, 09:32 PM
RE: Gilfillan 5B8 - by dseverson - 04-02-2015, 05:13 PM
RE: Gilfillan 5B8 - by dseverson - 04-03-2015, 09:27 PM
RE: Gilfillan 5B8 - by Radioroslyn - 04-03-2015, 11:12 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
