Volume control for Philco 65
Where is this in the schematic/circuit? I'm looking at the schematic trying to find it so I can try to help someone out with a problem (volume control is running hot?), but I don't even see a volume control in the schematic at all.
Volume control for Philco 65 - by BrendaAnnD - 04-02-2015, 10:14 PM
RE: Volume control for Philco 65 - by klondike98 - 04-02-2015, 10:42 PM
RE: Volume control for Philco 65 - by Ron Ramirez - 04-02-2015, 10:54 PM
RE: Volume control for Philco 65 - by klondike98 - 04-02-2015, 10:58 PM
RE: Volume control for Philco 65 - by BrendaAnnD - 04-03-2015, 01:43 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
