Volume control for Philco 65
ooops... Icon_redface
thanks Ron!
Volume control for Philco 65 - by BrendaAnnD - 04-02-2015, 10:14 PM
RE: Volume control for Philco 65 - by klondike98 - 04-02-2015, 10:42 PM
RE: Volume control for Philco 65 - by Ron Ramirez - 04-02-2015, 10:54 PM
RE: Volume control for Philco 65 - by klondike98 - 04-02-2015, 10:58 PM
RE: Volume control for Philco 65 - by BrendaAnnD - 04-03-2015, 01:43 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
