42-1012 Tone control
Yes, it is usually connected without being soldered.
42-1012 Tone control - by vecher - 04-02-2015, 11:36 PM
RE: 42-1012 Tone control - by Radioroslyn - 04-03-2015, 07:15 AM
RE: 42-1012 Tone control - by morzh - 04-03-2015, 08:28 AM
RE: 42-1012 Tone control - by vecher - 04-03-2015, 11:35 AM
RE: 42-1012 Tone control - by morzh - 04-03-2015, 11:47 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
