Need info: Stewart Warner 950
I could always try making socket adapters and use some sort of octal triode or a heptode wired as a triode.. but day-um, the gain would be ridiculous compared to a 27, and I'd probably get nothing but oscillation. I could probably replace both 45's with a 6SN7.. Icon_smile Oops.. nope, wrong filament voltage..
Need info: Stewart Warner 950 - by BrendaAnnD - 04-01-2015, 07:52 PM
RE: Need info: Stewart Warner 950 - by BrendaAnnD - 04-02-2015, 01:18 AM
RE: Need info: Stewart Warner 950 - by BrendaAnnD - 04-02-2015, 09:34 AM
RE: Need info: Stewart Warner 950 - by BrendaAnnD - 04-02-2015, 09:20 PM
RE: Need info: Stewart Warner 950 - by BrendaAnnD - 04-03-2015, 01:39 PM
RE: Need info: Stewart Warner 950 - by KCMike - 04-03-2015, 05:16 PM
RE: Need info: Stewart Warner 950 - by BrendaAnnD - 04-03-2015, 09:40 PM
RE: Need info: Stewart Warner 950 - by BrendaAnnD - 04-03-2015, 09:41 PM
RE: Need info: Stewart Warner 950 - by BrendaAnnD - 04-03-2015, 11:10 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
There are currently 3348 online users. [Complete List]
» 1 Member(s) | 3347 Guest(s)
