Philco's most expensive radio
Here's Model 16CPX. I forgot to mention above that this was Philco's special "Century of Progress" model, demonstrated at the 1933 Century of Progress World's Fair in Chicago.
http://www.philcoradio.com/gallery/1933c.htm#g
And here's a 1935 Model 509X.
http://www.philcoradio.com/gallery/1935b.htm#i
Philco's most expensive radio - by Chris Drumma - 12-20-2005, 08:50 AM
[No subject] - by Ron Ramirez - 12-20-2005, 09:39 AM
[No subject] - by 49Stude63 - 12-20-2005, 01:36 PM
[No subject] - by Ron Ramirez - 12-21-2005, 09:09 PM
[No subject] - by Bill Hutchinson - 12-21-2005, 10:18 PM
[No subject] - by Terry Judkins - 12-22-2005, 10:49 PM
[No subject] - by Ron Ramirez - 12-22-2005, 11:06 PM
[No subject] - by Ron Ramirez - 12-22-2005, 11:17 PM
[No subject] - by Guest - 03-12-2006, 08:26 PM
There are currently 7556 online users. [Complete List]
» 1 Member(s) | 7555 Guest(s)
