philco 40-135 Static problem
Good morning,
 I have a Philco 40-135    http://www.nostalgiaair.org/PagesByModel...013328.pdf
That I have recapped, replaced the output transformer replaced the deteriorated wiring checked and replaced out of spec resistors , tubes check good and have even replaced them one a a time to no improvement, looked for bad solder joints and things touching that shouldn't and cleaned and lubed the switch.
   I get a lot of static between the stronger stations, they come in great but the more distant ones have some static. It doesn't seem to matter how long I leave it on I also have a 40-140 that plays great. Should I start looking at the Mica Caps? Not sure where to go at this point. Thanks
Eric
philco 40-135 Static problem - by Eric - 04-05-2015, 10:54 AM
RE: philco 40-135 Static problem - by Radioroslyn - 04-05-2015, 11:28 AM
RE: philco 40-135 Static problem - by Eric - 04-05-2015, 11:37 AM
RE: philco 40-135 Static problem - by Eric - 04-05-2015, 12:22 PM
RE: philco 40-135 Static problem - by Eric - 04-05-2015, 04:45 PM
RE: philco 40-135 Static problem - by Radioroslyn - 04-05-2015, 05:17 PM
RE: philco 40-135 Static problem - by David - 04-05-2015, 08:13 PM
RE: philco 40-135 Static problem - by Eric - 04-06-2015, 09:48 AM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
New member
Hello all.  New member here. I bought a Predicta TV for my teenage son (who is into all things vintage, see attached pic...Jsmith5690 — 12:47 PM
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Make sure the person who answered is not a scammer (lots of these there now) and the Trus A S, whoever they are and wher...morzh — 12:38 PM
There are currently 1438 online users. [Complete List]
» 3 Member(s) | 1435 Guest(s)
