philco 40-135 Static problem
No go, the static seems to come and go to varying degrees, I have looked for bad solder joints and what ever I can think of just when I think I have it and put it in the cabinet it starts again. The static reminds me of what you get on AM when thunder storms are in the area ( there aren't any today here).
philco 40-135 Static problem - by Eric - 04-05-2015, 10:54 AM
RE: philco 40-135 Static problem - by Radioroslyn - 04-05-2015, 11:28 AM
RE: philco 40-135 Static problem - by Eric - 04-05-2015, 11:37 AM
RE: philco 40-135 Static problem - by Eric - 04-05-2015, 12:22 PM
RE: philco 40-135 Static problem - by Eric - 04-05-2015, 04:45 PM
RE: philco 40-135 Static problem - by Radioroslyn - 04-05-2015, 05:17 PM
RE: philco 40-135 Static problem - by David - 04-05-2015, 08:13 PM
RE: philco 40-135 Static problem - by Eric - 04-06-2015, 09:48 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
