Philco 42-1012 Power up
Thanks. You guys have made your point very nicely. I will hook up speaker and then power up .. I assume I don't need to hookup Phone if I don't select it.
To be on safe side I can hook up thru the dim bulb tester with a 200 watt bulb. the radio states its 125 watts . I read Bulb should be 1.5 to 2 times input wattage. Which would allow the radio to work. Please correct me if that is not true..
Thanks again
Skip...
Philco 42-1012 Power up - by vecher - 04-04-2015, 10:16 PM
RE: Philco 42-1012 Power up - by morzh - 04-04-2015, 10:38 PM
RE: Philco 42-1012 Power up - by Radioroslyn - 04-04-2015, 10:52 PM
RE: Philco 42-1012 Power up - by morzh - 04-05-2015, 05:21 PM
RE: Philco 42-1012 Power up - by vecher - 04-05-2015, 05:42 PM
RE: Philco 42-1012 Power up - by morzh - 04-05-2015, 06:01 PM
RE: Philco 42-1012 Power up - by vecher - 04-05-2015, 06:31 PM
RE: Philco 42-1012 Power up - by morzh - 04-05-2015, 08:43 PM
RE: Philco 42-1012 Power up - by vecher - 04-05-2015, 09:34 PM
RE: Philco 42-1012 Power up - by Radioroslyn - 04-05-2015, 11:08 PM
RE: Philco 42-1012 Power up - by vecher - 04-06-2015, 02:48 PM
RE: Philco 42-1012 Power up - by morzh - 04-06-2015, 02:56 PM
RE: Philco 42-1012 Power up - by vecher - 04-07-2015, 11:39 AM
RE: Philco 42-1012 Power up - by morzh - 04-07-2015, 12:13 PM
RE: Philco 42-1012 Power up - by vecher - 04-07-2015, 01:31 PM
RE: Philco 42-1012 Power up - by Chuck Schwark - 04-07-2015, 02:08 PM
RE: Philco 42-1012 Power up - by morzh - 04-07-2015, 02:57 PM
RE: Philco 42-1012 Power up - by vecher - 04-07-2015, 03:15 PM
RE: Philco 42-1012 Power up - by vecher - 04-07-2015, 08:50 PM
RE: Philco 42-1012 Power up - by Radioroslyn - 04-07-2015, 09:00 PM
RE: Philco 42-1012 Power up - by vecher - 04-08-2015, 03:14 PM
RE: Philco 42-1012 Power up - by morzh - 04-08-2015, 03:16 PM
RE: Philco 42-1012 Power up - by vecher - 04-11-2015, 02:35 PM
RE: Philco 42-1012 Power up - by morzh - 04-11-2015, 02:46 PM
RE: Philco 42-1012 Power up - by vecher - 04-11-2015, 07:55 PM
RE: Philco 42-1012 Power up - by Radioroslyn - 04-11-2015, 08:31 PM
RE: Philco 42-1012 Power up - by vecher - 04-12-2015, 10:13 PM
RE: Philco 42-1012 Power up - by morzh - 04-13-2015, 12:06 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
