Philco 42-1012 Power up
Ok Radio powers up OK. Volume is very low can hear a low hum when all the way up. NO signals on any band. even with my signal generator. Almost seems that the push buttons for changing bans are not working. The on off button does work.
Hard to tell. But I think I would get something on some a band. no change in volume when changing bands either. Even with no signals I would think volume should be noise.. But i am not getting that either.
What would be the next step..
Thanks
Skip...
Philco 42-1012 Power up - by vecher - 04-04-2015, 10:16 PM
RE: Philco 42-1012 Power up - by morzh - 04-04-2015, 10:38 PM
RE: Philco 42-1012 Power up - by Radioroslyn - 04-04-2015, 10:52 PM
RE: Philco 42-1012 Power up - by morzh - 04-05-2015, 05:21 PM
RE: Philco 42-1012 Power up - by vecher - 04-05-2015, 05:42 PM
RE: Philco 42-1012 Power up - by morzh - 04-05-2015, 06:01 PM
RE: Philco 42-1012 Power up - by vecher - 04-05-2015, 06:31 PM
RE: Philco 42-1012 Power up - by morzh - 04-05-2015, 08:43 PM
RE: Philco 42-1012 Power up - by vecher - 04-05-2015, 09:34 PM
RE: Philco 42-1012 Power up - by Radioroslyn - 04-05-2015, 11:08 PM
RE: Philco 42-1012 Power up - by vecher - 04-06-2015, 02:48 PM
RE: Philco 42-1012 Power up - by morzh - 04-06-2015, 02:56 PM
RE: Philco 42-1012 Power up - by vecher - 04-07-2015, 11:39 AM
RE: Philco 42-1012 Power up - by morzh - 04-07-2015, 12:13 PM
RE: Philco 42-1012 Power up - by vecher - 04-07-2015, 01:31 PM
RE: Philco 42-1012 Power up - by Chuck Schwark - 04-07-2015, 02:08 PM
RE: Philco 42-1012 Power up - by morzh - 04-07-2015, 02:57 PM
RE: Philco 42-1012 Power up - by vecher - 04-07-2015, 03:15 PM
RE: Philco 42-1012 Power up - by vecher - 04-07-2015, 08:50 PM
RE: Philco 42-1012 Power up - by Radioroslyn - 04-07-2015, 09:00 PM
RE: Philco 42-1012 Power up - by vecher - 04-08-2015, 03:14 PM
RE: Philco 42-1012 Power up - by morzh - 04-08-2015, 03:16 PM
RE: Philco 42-1012 Power up - by vecher - 04-11-2015, 02:35 PM
RE: Philco 42-1012 Power up - by morzh - 04-11-2015, 02:46 PM
RE: Philco 42-1012 Power up - by vecher - 04-11-2015, 07:55 PM
RE: Philco 42-1012 Power up - by Radioroslyn - 04-11-2015, 08:31 PM
RE: Philco 42-1012 Power up - by vecher - 04-12-2015, 10:13 PM
RE: Philco 42-1012 Power up - by morzh - 04-13-2015, 12:06 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
