Restoring a Model 19 Code 126
#64
Being as how one wrong move can turn your radio into a non-functioning shelf queen,
...you gotta ask yourself a question.
'Do I feel lucky?'
Well, do ya, punk?
Icon_lol
Seriously, though, you can do it if you follow the instructions on my website to the letter without deviating from them in any way. 31 or 32 gauge magnet wire for the secondary and 38 gauge for the primary. I do not recommend experimenting with wire gauges here, although other sizes might work...but then again they might not. I have only tried this using the wire gauges specified.
Pay careful attention to direction of your windings as well. This is important!
http://www.philcoradio.com/notebook/supercnv.htm
If you do it right...it will tune in stations across the bands upon the first powerup after making the conversion. You will have to align the set, of course.
Restoring a Model 19 Code 126 - by markmokris - 03-06-2015, 12:18 AM
RE: Restoring a Model 19 Code 126 - by klondike98 - 03-06-2015, 08:55 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-06-2015, 02:41 PM
RE: Restoring a Model 19 Code 126 - by klondike98 - 03-06-2015, 03:03 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-06-2015, 03:59 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-06-2015, 10:38 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-07-2015, 05:54 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-07-2015, 11:19 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-07-2015, 11:23 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-08-2015, 03:37 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-09-2015, 11:16 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-10-2015, 08:16 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-11-2015, 04:01 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-11-2015, 06:25 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-11-2015, 07:25 PM
RE: Restoring a Model 19 Code 126 - by VE6ZRT - 03-11-2015, 07:33 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-11-2015, 07:53 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-11-2015, 08:45 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-11-2015, 10:06 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-11-2015, 10:24 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-12-2015, 04:11 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-14-2015, 08:58 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-14-2015, 09:41 AM
RE: Restoring a Model 19 Code 126 - by morzh - 03-14-2015, 10:52 AM
RE: Restoring a Model 19 Code 126 - by morzh - 03-14-2015, 10:59 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-15-2015, 06:05 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-15-2015, 07:42 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-17-2015, 02:13 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-17-2015, 08:46 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-17-2015, 11:11 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-17-2015, 11:32 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-21-2015, 05:45 PM
RE: Restoring a Model 19 Code 126 - by klondike98 - 03-21-2015, 07:20 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-22-2015, 09:45 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-22-2015, 09:52 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-24-2015, 09:23 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-24-2015, 09:24 AM
RE: Restoring a Model 19 Code 126 - by klondike98 - 03-24-2015, 09:46 AM
RE: Restoring a Model 19 Code 126 - by VE6ZRT - 03-24-2015, 12:26 PM
RE: Restoring a Model 19 Code 126 - by Mondial - 03-24-2015, 12:57 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-24-2015, 03:08 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-24-2015, 08:44 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-28-2015, 09:00 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-06-2015, 11:31 AM
RE: Restoring a Model 19 Code 126 - by Ron Ramirez - 04-07-2015, 08:44 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-07-2015, 03:34 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-10-2015, 02:19 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-11-2015, 03:53 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-14-2015, 09:33 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-21-2015, 03:49 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-24-2015, 08:25 AM
RE: Restoring a Model 19 Code 126 - by Eliot Ness - 04-24-2015, 10:18 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-24-2015, 11:29 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 12-05-2015, 02:36 PM
Users browsing this thread: 23 Guest(s)
There are currently 6694 online users. [Complete List]
» 2 Member(s) | 6692 Guest(s)
