Philco 42-1012 Power up
Skip,
It is difficult to just tell you what to do, as you are there and we are not.
I do not know your proficiency level with tubes, so until I (we) do, telling you "go there touch that" would be geopardizing your life.
If though you poke around more and tell us what gpyou see and measure, we will be able to help you a bit more.
When I say grid caps, well, if there are no caps there are still grids, so same technique applies except the. grid is a pin, it is close to other pin and touching it becomes more difficult.
Start with something. If you know what you are doing, touch those grids.
Measure some Voltages. You gotta start from somewhere.
PS. Do you have any equipment? I mean, other than a light bulb.
Philco 42-1012 Power up - by vecher - 04-04-2015, 10:16 PM
RE: Philco 42-1012 Power up - by morzh - 04-04-2015, 10:38 PM
RE: Philco 42-1012 Power up - by Radioroslyn - 04-04-2015, 10:52 PM
RE: Philco 42-1012 Power up - by morzh - 04-05-2015, 05:21 PM
RE: Philco 42-1012 Power up - by vecher - 04-05-2015, 05:42 PM
RE: Philco 42-1012 Power up - by morzh - 04-05-2015, 06:01 PM
RE: Philco 42-1012 Power up - by vecher - 04-05-2015, 06:31 PM
RE: Philco 42-1012 Power up - by morzh - 04-05-2015, 08:43 PM
RE: Philco 42-1012 Power up - by vecher - 04-05-2015, 09:34 PM
RE: Philco 42-1012 Power up - by Radioroslyn - 04-05-2015, 11:08 PM
RE: Philco 42-1012 Power up - by vecher - 04-06-2015, 02:48 PM
RE: Philco 42-1012 Power up - by morzh - 04-06-2015, 02:56 PM
RE: Philco 42-1012 Power up - by vecher - 04-07-2015, 11:39 AM
RE: Philco 42-1012 Power up - by morzh - 04-07-2015, 12:13 PM
RE: Philco 42-1012 Power up - by vecher - 04-07-2015, 01:31 PM
RE: Philco 42-1012 Power up - by Chuck Schwark - 04-07-2015, 02:08 PM
RE: Philco 42-1012 Power up - by morzh - 04-07-2015, 02:57 PM
RE: Philco 42-1012 Power up - by vecher - 04-07-2015, 03:15 PM
RE: Philco 42-1012 Power up - by vecher - 04-07-2015, 08:50 PM
RE: Philco 42-1012 Power up - by Radioroslyn - 04-07-2015, 09:00 PM
RE: Philco 42-1012 Power up - by vecher - 04-08-2015, 03:14 PM
RE: Philco 42-1012 Power up - by morzh - 04-08-2015, 03:16 PM
RE: Philco 42-1012 Power up - by vecher - 04-11-2015, 02:35 PM
RE: Philco 42-1012 Power up - by morzh - 04-11-2015, 02:46 PM
RE: Philco 42-1012 Power up - by vecher - 04-11-2015, 07:55 PM
RE: Philco 42-1012 Power up - by Radioroslyn - 04-11-2015, 08:31 PM
RE: Philco 42-1012 Power up - by vecher - 04-12-2015, 10:13 PM
RE: Philco 42-1012 Power up - by morzh - 04-13-2015, 12:06 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
