Model 80 schematic clarification
The Dejavu was what I needed Thanks.
Model 80 schematic clarification - by simplex1040 - 04-07-2015, 12:40 PM
RE: Model 80 schematic clarification - by simplex1040 - 04-07-2015, 02:54 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
