  • 1 Vote(s) - 3 Average
Model 57 compensator values?
Obviously regen cap should go where it was before as otherwise you won't have the regen control easily accessible as intended, from the back of the chassis.
Model 57 compensator values? - by earlyradios - 04-07-2015, 10:34 AM
RE: Model 57 compensator values? - by klondike98 - 04-07-2015, 10:46 AM
RE: Model 57 compensator values? - by Radioroslyn - 04-07-2015, 08:47 PM
RE: Model 57 compensator values? - by morzh - 04-07-2015, 09:12 PM
RE: Model 57 compensator values? - by Radioroslyn - 04-07-2015, 10:00 PM
RE: Model 57 compensator values? - by morzh - 04-07-2015, 10:16 PM
RE: Model 57 compensator values? - by Radioroslyn - 04-07-2015, 10:37 PM
RE: Model 57 compensator values? - by earlyradios - 04-08-2015, 12:54 AM
RE: Model 57 compensator values? - by Ron Ramirez - 04-08-2015, 07:41 AM
RE: Model 57 compensator values? - by earlyradios - 04-08-2015, 10:13 AM
RE: Model 57 compensator values? - by earlyradios - 04-12-2015, 05:47 PM
RE: Model 57 compensator values? - by klondike98 - 04-12-2015, 06:22 PM
RE: Model 57 compensator values? - by Ron Ramirez - 04-12-2015, 06:34 PM
RE: Model 57 compensator values? - by earlyradios - 04-13-2015, 12:04 AM
RE: Model 57 compensator values? - by earlyradios - 04-13-2015, 12:05 AM
RE: Model 57 compensator values? - by Radioroslyn - 04-13-2015, 05:48 AM
RE: Model 57 compensator values? - by earlyradios - 04-13-2015, 10:32 AM
RE: Model 57 compensator values? - by Radioroslyn - 04-13-2015, 07:44 PM
RE: Model 57 compensator values? - by earlyradios - 04-14-2015, 10:30 AM
RE: Model 57 compensator values? - by earlyradios - 04-20-2015, 10:30 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
