  • 1 Vote(s) - 3 Average
Model 57 compensator values?
Take a look at the back side of each trimmer. The Bakelite insulator should have one letter stamped multiple times all over it. Match that letter to the parts list.
One should be stamped with the letter A, one with D, and one with S. The regeneration control, part (19), probably will not have a letter on it.
A - part (12), IF primary, part no. 04000-A
D - part (18 ), IF secondary, part no. 04000-D
S - part (15), low frequency padder, part no. 04000-S
Model 57 compensator values? - by earlyradios - 04-07-2015, 10:34 AM
RE: Model 57 compensator values? - by klondike98 - 04-07-2015, 10:46 AM
RE: Model 57 compensator values? - by Radioroslyn - 04-07-2015, 08:47 PM
RE: Model 57 compensator values? - by morzh - 04-07-2015, 09:12 PM
RE: Model 57 compensator values? - by Radioroslyn - 04-07-2015, 10:00 PM
RE: Model 57 compensator values? - by morzh - 04-07-2015, 10:16 PM
RE: Model 57 compensator values? - by Radioroslyn - 04-07-2015, 10:37 PM
RE: Model 57 compensator values? - by earlyradios - 04-08-2015, 12:54 AM
RE: Model 57 compensator values? - by Ron Ramirez - 04-08-2015, 07:41 AM
RE: Model 57 compensator values? - by earlyradios - 04-08-2015, 10:13 AM
RE: Model 57 compensator values? - by earlyradios - 04-12-2015, 05:47 PM
RE: Model 57 compensator values? - by klondike98 - 04-12-2015, 06:22 PM
RE: Model 57 compensator values? - by Ron Ramirez - 04-12-2015, 06:34 PM
RE: Model 57 compensator values? - by earlyradios - 04-13-2015, 12:04 AM
RE: Model 57 compensator values? - by earlyradios - 04-13-2015, 12:05 AM
RE: Model 57 compensator values? - by Radioroslyn - 04-13-2015, 05:48 AM
RE: Model 57 compensator values? - by earlyradios - 04-13-2015, 10:32 AM
RE: Model 57 compensator values? - by Radioroslyn - 04-13-2015, 07:44 PM
RE: Model 57 compensator values? - by earlyradios - 04-14-2015, 10:30 AM
RE: Model 57 compensator values? - by earlyradios - 04-20-2015, 10:30 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
