Wire Colors
Can anyone tell me what the wire colors should be within the chassis of a 37-650? Is there a set color code array for these radios? Mine have mostly faded to an almost uniform brown color at this point, and it makes replacing them difficult when I choose to do so. I have 4 Philcos to rebuild, and would like to get the colors right... The schematics are almost useless on that point- only certain items have colors listed... Wish I had a wiring diagram with wire lengths and colors listed...
Thanks-
Scott
Old Cars, Old Radios, Old Pipes and Young Women... What more is there?
Wire Colors - by Robbie Roberts - 12-23-2005, 06:13 PM
[No subject] - by Bill Hutchinson - 12-23-2005, 11:07 PM
Color Code of Philco Wiring - by Chuck Schwark - 12-24-2005, 12:06 AM
[No subject] - by Ron Ramirez - 12-24-2005, 01:10 AM
[No subject] - by Chuck Schwark - 12-24-2005, 10:01 AM
[No subject] - by Guest - 12-24-2005, 03:29 PM
[No subject] - by Bill Hutchinson - 12-24-2005, 06:39 PM
Which RMA code? - by Robbie Roberts - 12-24-2005, 07:10 PM
[No subject] - by Chuck Schwark - 12-24-2005, 10:15 PM
There are currently 8963 online users. [Complete List]
» 1 Member(s) | 8962 Guest(s)
