Threads: 310
City: Kings Park NY
My veneer repair yesterday failed totally! I forgot to sand the veneer and it had the old finish from the radio I tore it off of on it... Duh!
It came off and I have to scrape and re-glue a new piece on.
Tomorrow I plane the repairs, move on to the rest on the face and then re-attach the face to the frame. Maybe it will dismantle the body to make stripping and Toning easier.... Hmmmmm.....
We shall see!
Kirk
AC: 4 DC: 1
Users browsing this thread: 22 Guest(s)
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 8059 online users. [Complete List] » 1 Member(s) | 8058 Guest(s)
