37-650 console
Hi Paul & Welcome.
I would suspect that your plate voltage on the 6J5 is going to be very low. If the 6J5 was used as an audio amp it would require much more voltage, but it isn't. It's used as a diode to convert the RF signal to audio and to develope AVC voltage to control the gain RF and IF stages.
The voltage should change as signal is applied to the antenna.  The alignment and the condition of the tubes will also have an effect on it too.
37-650 console - by ptc4248 - 04-09-2015, 07:50 PM
RE: 37-650 console - by Radioroslyn - 04-10-2015, 03:21 PM
RE: 37-650 console - by ptc4248 - 04-10-2015, 05:19 PM
RE: 37-650 console - by Radioroslyn - 04-10-2015, 07:24 PM
RE: 37-650 console - by ptc4248 - 04-12-2015, 03:30 PM
RE: 37-650 console - by ptc4248 - 04-12-2015, 05:00 PM
RE: 37-650 console - by Radioroslyn - 04-13-2015, 06:00 AM
RE: 37-650 console - by ptc4248 - 04-13-2015, 08:50 AM
RE: 37-650 console - by Radioroslyn - 04-13-2015, 07:48 PM
RE: 37-650 console - by morzh - 04-13-2015, 07:53 PM
RE: 37-650 console - by ptc4248 - 04-13-2015, 08:55 PM
RE: 37-650 console - by ptc4248 - 04-16-2015, 08:27 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
