Missing 16X-126 dial mount
Hello, everyone!
I'm working on a 16X chassis (version #4, 4 band) and there is a part missing in the dial assembly.  I'd like to find out what to call it so I can seek the right item.
The tuning knob shafts are present and functioning correctly but the metal disc that supports the dial is missing.  I presume that this disc would attach to the shaft extending forward from the variable tuning capacitor.  Perhaps this part was also used in other sets of the era?
What am I looking for?  Is it simply called "Dial Assembly?  I see that entry on the parts list but wonder if applies to what I'm looking for.
Thanks, in advance, for your replies.
Mike, K9UW
Amherst, WI
Mike, K9UW
Amherst, WI
Missing 16X-126 dial mount - by k9uw - 04-10-2015, 03:33 PM
RE: Missing 16X-126 dial mount - by klondike98 - 04-10-2015, 04:15 PM
RE: Missing 16X-126 dial mount - by k9uw - 04-10-2015, 04:37 PM
RE: Missing 16X-126 dial mount - by Ron Ramirez - 04-10-2015, 06:05 PM
RE: Missing 16X-126 dial mount - by klondike98 - 04-10-2015, 07:02 PM
RE: Missing 16X-126 dial mount - by k9uw - 04-10-2015, 07:11 PM
RE: Missing 16X-126 dial mount - by Ron Ramirez - 04-15-2015, 08:47 PM
RE: Missing 16X-126 dial mount - by k9uw - 04-15-2015, 09:07 PM
RE: Missing 16X-126 dial mount - by Ron Ramirez - 04-15-2015, 09:57 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
