Threads: 562
I think Kirk at some point described his method and it was different. The only oversize is the one outside the external wall (bezel) contour, unless you mean this oversize.
RE: Mikes 16B - by morzh - 04-10-2015, 08:25 PM
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 4098 online users. [Complete List] » 2 Member(s) | 4096 Guest(s)
