Vernier shaft repair
That little ball is not attached. It's held in through spring pressure against the shaft.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Vernier shaft repair - by dixierat - 01-19-2009, 09:48 PM
Re: Vernier shaft repair - by exray - 01-20-2009, 05:10 AM
Re: Vernier shaft repair - by dixierat - 01-20-2009, 08:14 PM
Re: Vernier shaft repair - by BDM - 01-20-2009, 09:35 PM
Re: Vernier shaft repair - by dixierat - 01-20-2009, 10:19 PM
Re: Vernier shaft repair - by BDM - 01-20-2009, 11:03 PM
Re: Vernier shaft repair - by dixierat - 01-20-2009, 11:35 PM
Re: Vernier shaft repair - by exray - 01-20-2009, 11:40 PM
Re: Vernier shaft repair - by BDM - 01-20-2009, 11:54 PM
Re: Vernier shaft repair - by dixierat - 01-21-2009, 11:16 PM
Re: Vernier shaft repair - by Texasrocker - 01-22-2009, 12:30 AM
Re: Vernier shaft repair - by exray - 01-22-2009, 06:36 AM
Re: Vernier shaft repair - by dixierat - 01-22-2009, 08:43 PM
Re: Vernier shaft repair - by Texasrocker - 01-23-2009, 03:53 AM
Re: Vernier shaft repair - by dixierat - 01-23-2009, 10:03 PM
There are currently 5048 online users. [Complete List]
» 1 Member(s) | 5047 Guest(s)
