Threads: 310
City: Kings Park NY
Unclamped, sanded with block, and they look pretty darn good!
Toner will hide all the little imperfections.
A few more repairs and the face is DONE!
Here are the pics:
AC: 4 DC: 1
Users browsing this thread: 29 Guest(s)
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 9948 online users. [Complete List] » 2 Member(s) | 9946 Guest(s)
