Speaker cabinet, Emerson, and Kadette Resto Chronicles
Sam! Saaaam!
RE: Speaker cabinet, Emerson, and Kadette Resto Chronicles - by morzh - 04-11-2015, 08:16 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
There are currently 2313 online users. [Complete List]
» 3 Member(s) | 2310 Guest(s)
