The 39-116 project: the beginning
I bought 100uF some hi volts NP cap from Parts express a gear ago when fixing my HP oscillator.
http://www.parts-express.com/cat/non-pol...itors/1385
They are 100V max but can be serialized.
The 39-116 project: the beginning - by BrendaAnnD - 03-20-2015, 05:47 AM
RE: The 39-116 project: the beginning - by morzh - 03-20-2015, 10:39 AM
RE: The 39-116 project: the beginning - by morzh - 03-20-2015, 02:39 PM
RE: The 39-116 project: the beginning - by morzh - 03-28-2015, 11:54 AM
RE: The 39-116 project: the beginning - by morzh - 03-28-2015, 12:43 PM
RE: The 39-116 project: the beginning - by morzh - 03-29-2015, 11:04 AM
RE: The 39-116 project: the beginning - by morzh - 03-29-2015, 11:37 AM
RE: The 39-116 project: the beginning - by morzh - 04-15-2015, 09:39 AM
RE: The 39-116 project: the beginning - by morzh - 04-15-2015, 09:59 AM
RE: The 39-116 project: the beginning - by morzh - 04-16-2015, 05:11 PM
RE: The 39-116 project: the beginning - by murf - 04-19-2015, 05:49 PM
RE: The 39-116 project: the beginning - by Edisla - 10-24-2017, 03:55 PM
Users browsing this thread: 15 Guest(s)
The speaker table error?
Philco 70 antenna lead
