Philco 18 code 121 RF coil rewind
Welcome to the Phorum!! Have not rewound an 18 but someone will chime in here I'm sure. One caution often repeated here....make note of the direction of the winding!
Philco 18 code 121 RF coil rewind - by Jason K - 04-15-2015, 11:37 AM
RE: Philco 18 code 121 RF coil rewind - by klondike98 - 04-15-2015, 11:41 AM
RE: Philco 18 code 121 RF coil rewind - by morzh - 04-15-2015, 11:43 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
