Threads: 337
City: lawrenceville nj
(04-15-2015, 11:52 AM)OldRestorer Wrote: I could always paint it. That would make the repairs easier. Could use wood filler all over and give it a nice white and black lacquer finish.....
Should I? could I? Would I?
Ok back to work, ![Icon_rolleyes Icon_rolleyes](https://philcoradio.com/phorum/images/smilies/icon_rolleyes.gif)
I double dog dare you
sam
RE: Mikes 16B - by sam - 04-15-2015, 12:55 PM
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 3408 online users. [Complete List] » 2 Member(s) | 3406 Guest(s)
