speaker reconing
(04-16-2015, 04:27 PM)jerryhawthorne Wrote:  I had a couple done by "Ken G" on the alternate forum and they were great.  The last one I did myself, it is not rocket science and saves money on shipping back and forth.  The really hard part is finding a source of cones.  They are expensive, a little over $2.00 each.  Buy a bunch as the shipping is more than the speaker cone cost.  Find one of the right size and make it a DYI project.  People here can guide you.  It was fun and all you need is some rubber cement and white glue.
Jerry
How about sharing some links where you can get the cones?  Thanks.
Crist
speaker reconing - by Tubesforme - 04-15-2015, 03:54 PM
RE: speaker reconing - by RodB - 04-15-2015, 04:33 PM
RE: speaker reconing - by Eric Adams - 04-15-2015, 06:16 PM
RE: speaker reconing - by Tubesforme - 04-15-2015, 10:20 PM
RE: speaker reconing - by Steve D - 04-16-2015, 08:33 AM
RE: speaker reconing - by jerryhawthorne - 04-16-2015, 04:27 PM
RE: speaker reconing - by Crist Rigotti - 04-16-2015, 09:07 PM
RE: speaker reconing - by jerryhawthorne - 04-17-2015, 12:38 AM
RE: speaker reconing - by Eliot Ness - 04-17-2015, 01:19 AM
RE: speaker reconing - by Crist Rigotti - 04-17-2015, 02:12 AM
RE: speaker reconing - by klondike98 - 04-17-2015, 09:52 AM
RE: speaker reconing - by jerryhawthorne - 04-17-2015, 12:01 PM
RE: speaker reconing - by Bob Andersen - 04-23-2015, 04:57 PM
RE: speaker reconing - by klondike98 - 04-23-2015, 05:37 PM
RE: speaker reconing - by jerryhawthorne - 04-23-2015, 05:50 PM
RE: speaker reconing - by Bob Andersen - 04-24-2015, 01:30 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
