pHILCO MODEL 20 CABINET
How about a reproduction cabinet from Dick Oliver?
http://www.philcoradio.com/resource.htm
He does excellent work. He can make either the early "plain" cabinet or the later revised "deluxe" cabinet.
pHILCO MODEL 20 CABINET - by phil vanderoef - 01-22-2009, 11:18 PM
Re: pHILCO MODEL 20 CABINET - by Texasrocker - 01-23-2009, 02:57 AM
Re: pHILCO MODEL 20 CABINET - by Ron Ramirez - 01-23-2009, 07:54 AM
Re: pHILCO MODEL 20 CABINET - by Michael Dennis - 01-25-2009, 01:22 AM
Re: pHILCO MODEL 20 CABINET - by Ron Ramirez - 01-25-2009, 09:06 PM
Re: pHILCO MODEL 20 CABINET - by Michael Dennis - 01-25-2009, 11:30 PM
There are currently 4573 online users. [Complete List]
» 1 Member(s) | 4572 Guest(s)
