Grandfather Clock Chassis 70 "no volume" Help
John
A new multi-tapped resistor such as that used in the original is, unfortunately, unobtainium these days. Replacement with individual resistors is your only option.
I have done this in the past by removing ALL of the resistance wire from the multi-tapped unit and using the terminals as tie points for not only the original wires that connected to the several terminals, but also for new resistors to replace the individual sections.
Grandfather Clock Chassis 70 "no volume" Help - by Guest - 12-22-2005, 11:00 PM
[No subject] - by Ron Ramirez - 12-23-2005, 12:03 AM
[No subject] - by Guest - 12-23-2005, 07:07 PM
[No subject] - by Ron Ramirez - 12-24-2005, 01:03 AM
[No subject] - by Terry Judkins - 12-24-2005, 11:18 AM
[No subject] - by Guest - 12-24-2005, 04:00 PM
[No subject] - by Ron Ramirez - 12-24-2005, 04:23 PM
[No subject] - by Guest - 12-24-2005, 04:29 PM
[No subject] - by Chuck Schwark - 12-24-2005, 04:35 PM
There are currently 9256 online users. [Complete List]
» 2 Member(s) | 9254 Guest(s)
