Work on the Philco 39-30 has begun
Here is the makeshift antenna.
Slave to an RCA Victor CTC-25
RE: Work on the Philco 39-30 has begun - by TheUniversalDave1 - 04-18-2015, 10:11 PM
RE: Work on the Philco 39-30 has begun - by sam - 04-19-2015, 12:44 PM
RE: Work on the Philco 39-30 has begun - by morzh - 04-20-2015, 11:35 PM
RE: Work on the Philco 39-30 has begun - by Arran - 04-21-2015, 03:41 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
