Work on the Philco 39-30 has begun
Is that 300 ohm twin lead connected to both the antenna and ground terminal? And it looks like you have a wire nut on the other end connecting them both? I wouldn't do that.
Just put a single wire on the antenna terminal only. 10' or so will work.
RE: Work on the Philco 39-30 has begun - by Nick3092 - 04-19-2015, 08:28 AM
RE: Work on the Philco 39-30 has begun - by sam - 04-19-2015, 12:44 PM
RE: Work on the Philco 39-30 has begun - by morzh - 04-20-2015, 11:35 PM
RE: Work on the Philco 39-30 has begun - by Arran - 04-21-2015, 03:41 AM
Users browsing this thread: 14 Guest(s)
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
