Work on the Philco 39-30 has begun
Most radios into the early 40's were designed as long wire radios, meaning no loop. Typically if a radio schematic shows just an antenna terminal on the schematic or shows an upside down triangle, that usually means it's a long wire. Most transformer sets are long wire, but some larger consoles were designed to have a built in loop (like the 40-180).
Most sets designed to use a loop will have a spiral square on the schematic indicating the loop antenna. It's also important to know that the loop was tuned for that particular radio. Meaning a loop from one radio may perform badly on another. Most often these are AC/DC transformerless sets. But not always.
RE: Work on the Philco 39-30 has begun - by Nick3092 - 04-19-2015, 11:44 AM
RE: Work on the Philco 39-30 has begun - by sam - 04-19-2015, 12:44 PM
RE: Work on the Philco 39-30 has begun - by morzh - 04-20-2015, 11:35 PM
RE: Work on the Philco 39-30 has begun - by Arran - 04-21-2015, 03:41 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
