38-12 power transformer
Thanks all. I really appreciate it. I did not make it to Nashville -- my kids wanted attention from me so I spent the day playing baseball and digging in the yard with them ;)... Really, couldn't have asked for a better day.
I found a 38-12 at a good price. I picked it up and see how it comes together. The chassis and components look in much better shape than what I have but the cabinet is worse for the wear. I may Frankenstein the two together.
38-12 power transformer - by ronlubke - 04-16-2015, 02:01 PM
RE: 38-12 power transformer - by klondike98 - 04-16-2015, 08:30 PM
RE: 38-12 power transformer - by Ron Ramirez - 04-16-2015, 09:06 PM
RE: 38-12 power transformer - by Arran - 04-16-2015, 11:27 PM
RE: 38-12 power transformer - by morzh - 04-17-2015, 03:09 PM
RE: 38-12 power transformer - by Ron Ramirez - 04-17-2015, 03:46 PM
RE: 38-12 power transformer - by ronlubke - 04-20-2015, 02:27 PM
RE: 38-12 power transformer - by ronlubke - 04-20-2015, 02:29 PM
RE: 38-12 power transformer - by morzh - 04-20-2015, 03:53 PM
RE: 38-12 power transformer - by ronlubke - 04-21-2015, 10:34 AM
RE: 38-12 power transformer - by morzh - 04-21-2015, 03:50 PM
RE: 38-12 power transformer - by ronlubke - 04-21-2015, 03:59 PM
RE: 38-12 power transformer - by morzh - 04-21-2015, 04:23 PM
RE: 38-12 power transformer - by ronlubke - 04-22-2015, 08:55 AM
RE: Advice for restoring 38-12 - by morzh - 04-16-2015, 05:27 PM
RE: Advice for restoring 38-12 - by klondike98 - 04-16-2015, 07:09 PM
RE: Advice for restoring 38-12 - by ronlubke - 04-16-2015, 07:15 PM
RE: Advice for restoring 38-12 - by ronlubke - 04-16-2015, 07:17 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
