Restoring a Model 19 Code 126
#74
On this latest rewind of the oscillator tickler coil I went to 28 turns instead of 27. I also moved the tickler up about 1/16 of an inch. As is, I only hear a popping sound with the radio on. However, when I attach a 2 ft. piece of wire to pin 4 (the cathode) of the 36 tube, the radio springs to life, sounds great, and I can tuned across the band.
I think this has the effect of a gimmick capacitor. I have tried other small capacitors to replace the wire, but nothing seems to work as well.
I may leave it this way for now with the intention of doing the 6A7 conversion in the near future.
Question about the shadow meter. My shadow meter tests well. If I connect a 9 volt battery, it gives full deflection. But in operation, the voltage across the meter goes from about 9.5V (no station) to 7.3V (station tuned in).
Does that sound right? I get very little deflection.
Any suggestions on that?
Thanks again guys,
Mark
Restoring a Model 19 Code 126 - by markmokris - 03-06-2015, 12:18 AM
RE: Restoring a Model 19 Code 126 - by klondike98 - 03-06-2015, 08:55 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-06-2015, 02:41 PM
RE: Restoring a Model 19 Code 126 - by klondike98 - 03-06-2015, 03:03 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-06-2015, 03:59 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-06-2015, 10:38 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-07-2015, 05:54 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-07-2015, 11:19 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-07-2015, 11:23 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-08-2015, 03:37 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-09-2015, 11:16 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-10-2015, 08:16 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-11-2015, 04:01 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-11-2015, 06:25 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-11-2015, 07:25 PM
RE: Restoring a Model 19 Code 126 - by VE6ZRT - 03-11-2015, 07:33 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-11-2015, 07:53 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-11-2015, 08:45 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-11-2015, 10:06 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-11-2015, 10:24 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-12-2015, 04:11 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-14-2015, 08:58 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-14-2015, 09:41 AM
RE: Restoring a Model 19 Code 126 - by morzh - 03-14-2015, 10:52 AM
RE: Restoring a Model 19 Code 126 - by morzh - 03-14-2015, 10:59 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-15-2015, 06:05 PM
RE: Restoring a Model 19 Code 126 - by morzh - 03-15-2015, 07:42 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-17-2015, 02:13 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-17-2015, 08:46 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-17-2015, 11:11 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-17-2015, 11:32 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-21-2015, 05:45 PM
RE: Restoring a Model 19 Code 126 - by klondike98 - 03-21-2015, 07:20 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-22-2015, 09:45 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-22-2015, 09:52 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-24-2015, 09:23 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-24-2015, 09:24 AM
RE: Restoring a Model 19 Code 126 - by klondike98 - 03-24-2015, 09:46 AM
RE: Restoring a Model 19 Code 126 - by VE6ZRT - 03-24-2015, 12:26 PM
RE: Restoring a Model 19 Code 126 - by Mondial - 03-24-2015, 12:57 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-24-2015, 03:08 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-24-2015, 08:44 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 03-28-2015, 09:00 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-06-2015, 11:31 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-07-2015, 03:34 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-10-2015, 02:19 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-11-2015, 03:53 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-14-2015, 09:33 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-21-2015, 03:49 PM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-24-2015, 08:25 AM
RE: Restoring a Model 19 Code 126 - by Eliot Ness - 04-24-2015, 10:18 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 04-24-2015, 11:29 AM
RE: Restoring a Model 19 Code 126 - by markmokris - 12-05-2015, 02:36 PM
There are currently 4617 online users. [Complete List]
» 1 Member(s) | 4616 Guest(s)
