Bakelite block challenge???
   Thanks for that information, it is very helpful.
   I still have a question about the value of the cap in question.. on the schematic it is #80 which says it is a .03 uF.
   Maybe I am looking at the wrong block, but in tracking the wires   from the heater of the rectifier tube I get them going to a .o3 cap , #80 [ on the schematic] but in that block it tells me that there are .05 caps in there.
    I feel that I am missing something here.
   Living in Calgary Alberta
Bakelite block challenge??? - by Dan Walker - 04-21-2015, 05:07 PM
RE: Bakelite block challenge??? - by radiohenry - 04-21-2015, 07:12 PM
RE: Bakelite block challenge??? - by sam - 04-21-2015, 07:16 PM
RE: Bakelite block challenge??? - by klondike98 - 04-21-2015, 07:24 PM
RE: Bakelite block challenge??? - by Dan Walker - 04-21-2015, 08:44 PM
RE: Bakelite block challenge??? - by klondike98 - 04-21-2015, 09:21 PM
RE: Bakelite block challenge??? - by Dan Walker - 04-23-2015, 09:45 AM
RE: Bakelite block challenge??? - by morzh - 04-23-2015, 10:52 AM
RE: Bakelite block challenge??? - by klondike98 - 04-23-2015, 12:29 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
