need parts
Hi,I am not familiar with your model so I am not sure if this will help.There are some reproduction faceplates (escutcheons) and knobs
available.I purchased some through a place in upstate N.Y. The name is Radio Daze. I do not want to give you the impression this is the only place to go as there may be others.Also there is a radio "junk yard" on the web that sells old parts. Sorry I can't be more specific ,but hope this helps some.Good luck in your search for parts, they are out there somewhere!
need parts - by Guest - 12-23-2005, 08:32 PM
[No subject] - by bill T - 12-24-2005, 09:04 AM
[No subject] - by Terry Burns - 12-24-2005, 09:47 AM
There are currently 10459 online users. [Complete List]
» 1 Member(s) | 10458 Guest(s)
