Silvertone 1720 Information
I have an Airline (Montgomery Ward) with similar 1933-34 styling, and it works on older maintenance.  I paid $150, so I think that's definitely in the ballpark.  Honestly, some of these are the best-styled radios ever made, my opinion.  But the others are right, they're not real collectible right now, so not drawing high prices.  That's good for us, if we want more of them!  :-)
From a technical point of view, your radio has parallel push-pull output 45-tubes.  A 45 tube sells for $20-30 if it tests good.  If they're all there and good, that's most of the value of the radio, just in the output tubes.  Ya done good.
Silvertone 1720 Information - by LisaC2014 - 04-23-2015, 05:09 PM
RE: Silvertone 1720 Information - by morzh - 04-23-2015, 05:22 PM
RE: Silvertone 1720 Information - by LisaC2014 - 04-23-2015, 05:30 PM
RE: Silvertone 1720 Information - by OldRestorer - 04-23-2015, 05:47 PM
RE: Silvertone 1720 Information - by LisaC2014 - 04-23-2015, 06:23 PM
RE: Silvertone 1720 Information - by klondike98 - 04-23-2015, 06:02 PM
RE: Silvertone 1720 Information - by LisaC2014 - 04-23-2015, 06:26 PM
RE: Silvertone 1720 Information - by Eliot Ness - 04-23-2015, 06:18 PM
RE: Silvertone 1720 Information - by LisaC2014 - 04-23-2015, 06:25 PM
RE: Silvertone 1720 Information - by morzh - 04-23-2015, 07:15 PM
RE: Silvertone 1720 Information - by LisaC2014 - 04-24-2015, 07:46 AM
RE: Silvertone 1720 Information - by klondike98 - 04-23-2015, 07:30 PM
RE: Silvertone 1720 Information - by LisaC2014 - 04-24-2015, 07:48 AM
RE: Silvertone 1720 Information - by Jayce - 04-23-2015, 08:10 PM
RE: Silvertone 1720 Information - by LisaC2014 - 04-24-2015, 07:52 AM
RE: Silvertone 1720 Information - by OldRestorer - 04-24-2015, 09:55 AM
RE: Silvertone 1720 Information - by LisaC2014 - 04-24-2015, 11:16 AM
RE: Silvertone 1720 Information - by Arran - 05-09-2015, 03:36 AM
RE: Silvertone 1720 Information - by morzh - 04-24-2015, 10:32 AM
RE: Silvertone 1720 Information - by LisaC2014 - 04-24-2015, 11:10 AM
RE: Silvertone 1720 Information - by morzh - 04-24-2015, 11:24 AM
RE: Silvertone 1720 Information - by LisaC2014 - 04-24-2015, 11:31 AM
RE: Silvertone 1720 Information - by Eliot Ness - 04-24-2015, 11:56 AM
RE: Silvertone 1720 Information - by LisaC2014 - 04-24-2015, 09:35 PM
RE: Silvertone 1720 Information - by morzh - 04-24-2015, 11:56 AM
RE: Silvertone 1720 Information - by palegreenthumb - 04-25-2015, 02:00 AM
RE: Silvertone 1720 Information - by morzh - 04-25-2015, 03:40 PM
RE: Silvertone 1720 Information - by Radioroslyn - 04-25-2015, 05:18 PM
RE: Silvertone 1720 Information - by Jayce - 04-25-2015, 08:18 PM
RE: Silvertone 1720 Information - by OldRestorer - 04-26-2015, 08:26 AM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
There are currently 2388 online users. [Complete List]
» 3 Member(s) | 2385 Guest(s)
