The 39-116 project: the beginning
#37
Hi!  I have a 41-616 and just installed this 40mfd motor run capacitor during my set's bi-annual shop job.  FYI: Philco changed the circuit from 30mfd to 45mfd to "increase positive action of the volume control motor".  It was a good change too.  This cap works great and fits perfectly in the slot below the motor.
Now if I can just locate a replacement drive belt.  On a 41-616, the motor drives a standard potentiometer with a belt. However, the one I have is on its last legs and slips too much to be able to actually turn the set off.  I'm afraid to adjust the tension any higher.
The 39-116 project: the beginning - by BrendaAnnD - 03-20-2015, 05:47 AM
RE: The 39-116 project: the beginning - by morzh - 03-20-2015, 10:39 AM
RE: The 39-116 project: the beginning - by morzh - 03-20-2015, 02:39 PM
RE: The 39-116 project: the beginning - by morzh - 03-28-2015, 11:54 AM
RE: The 39-116 project: the beginning - by morzh - 03-28-2015, 12:43 PM
RE: The 39-116 project: the beginning - by morzh - 03-29-2015, 11:04 AM
RE: The 39-116 project: the beginning - by morzh - 03-29-2015, 11:37 AM
RE: The 39-116 project: the beginning - by morzh - 04-15-2015, 09:39 AM
RE: The 39-116 project: the beginning - by morzh - 04-15-2015, 09:59 AM
RE: The 39-116 project: the beginning - by morzh - 04-16-2015, 05:11 PM
RE: The 39-116 project: the beginning - by murf - 04-19-2015, 05:49 PM
RE: The 39-116 project: the beginning - by sleuth255 - 04-26-2015, 10:09 AM
RE: The 39-116 project: the beginning - by Edisla - 10-24-2017, 03:55 PM
The speaker table error?
Philco 70 antenna lead
