Webcor 1133-1 Musicale Record Player
 You may have to remove the record changer to get the amplifier chassis out of the unit, sometimes there are some screws that will loosen off to allow one to lift the changer out. I would guess that you removed the knobs from the amp chassis and did not find any other screws holding it in, perhaps hidden by the knobs?
RE: Webcor 1133-1 Musicale Record Player - by Arran - 04-26-2015, 10:07 PM
