Magic Loop Antenna Idea - Advice?
That is a nice antenna - good work!
The problem is the need to adjust the variable capacitor on the antenna, especially if you want to sell the radio or give it as a gift.
Does anyone have any ideas on how to make an antenna which either does not need any such adjustments, or which adjusts automatically with some sort of circuit (does not have to be tubes)?
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
Magic Loop Antenna Idea - Advice? - by jayoungs - 01-12-2009, 10:01 AM
Re: Magic Loop Antenna Idea - Advice? - by exray - 01-12-2009, 07:23 PM
Re: Magic Loop Antenna Idea - Advice? - by FStephenMasek - 01-27-2009, 01:57 AM
Eico 232 VTVM Schematic
There are currently 8799 online users. [Complete List]
» 2 Member(s) | 8797 Guest(s)
