Philco turntable fries 7R7 tube in 47-1230
I stand corrected. The XXL is a 7A4. I need new (eye) glasses.
Thanks.
Re: Philco turntable fries 7R7 tube in 47-1230 - by codefox1 - 01-27-2009, 01:17 PM
Re: Philco turntable fries 7R7 tube in 47-1230 - by Guest - 01-27-2010, 08:47 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
