How To Remove Dial Pointer - 38-12
Could someone give me advice on how to remove the dial pointer on a Philco 38-12? The pointer needs to come off so I can remove and clean smoker residue from the tuning capacitor.
Richard
How To Remove Dial Pointer - 38-12 - by RQuam - 05-01-2015, 10:15 PM
RE: How To Remove Dial Pointer - 38-12 - by RQuam - 05-01-2015, 10:24 PM
RE: How To Remove Dial Pointer - 38-12 - by RQuam - 05-02-2015, 11:48 AM
There are currently 2320 online users. [Complete List]
» 3 Member(s) | 2317 Guest(s)
