How To Remove Dial Pointer - 38-12
It just pulls off. You may have to twist it back and forth a bit (carefully, while holding the tuning condenser plates fully meshed; that is, closed) but it should just pull off. In case of corrosion, do be careful...
How To Remove Dial Pointer - 38-12 - by RQuam - 05-01-2015, 10:15 PM
RE: How To Remove Dial Pointer - 38-12 - by Ron Ramirez - 05-01-2015, 10:19 PM
RE: How To Remove Dial Pointer - 38-12 - by RQuam - 05-01-2015, 10:24 PM
RE: How To Remove Dial Pointer - 38-12 - by RQuam - 05-02-2015, 11:48 AM
There are currently 5796 online users. [Complete List]
» 1 Member(s) | 5795 Guest(s)
