Tone control For a Philco 91 (late) /14
Well maybe you are! No the important part is that the volume control has FOUR connection not 3. Should have 3 connections close together and a fourth around the pot a bit. The fourth one is a tap that provides a negative feedback point. Without it the set will work but no bass boost.
RE: Tone control For a Philco 91 (late) /14 - by Radioroslyn - 05-03-2015, 04:57 AM
