Aww! What a cute wittle wadio!
You know you could have bot that on Ebay for 100.00! That little set could look slick. Pushbuttons look OK and it has call letters too. It is the right size for about a wall full of say like 50 small Philcos. Good luck.
RE: Aww! What a cute widdle wadio! - by morzh - 05-03-2015, 12:45 AM
RE: Aww! What a cute widdle wadio! - by Warren - 05-03-2015, 02:46 AM
RE: Aww! What a cute widdle wadio! - by morzh - 05-03-2015, 12:30 PM
RE: Aww! What a cute widdle wadio! - by Warren - 05-03-2015, 02:17 PM
RE: Aww! What a cute widdle wadio! - by Paul Philco322 - 05-03-2015, 10:41 AM
RE: Aww! What a cute widdle wadio! - by morzh - 05-03-2015, 02:52 PM
RE: Aww! What a cute wittle wadio! - by Warren - 05-03-2015, 03:56 PM
RE: Aww! What a cute wittle wadio! - by morzh - 05-03-2015, 05:14 PM
